i was wanting to fit an extra oil temprature gauge and coolant temprature gauge but not sure if mechanical or electrical required. also will i get a better,more accurate reading than the standard "one position gauge" fitted as standard. thakyou.
I've fitted an extra water temp guage to mine. The new guage shows a slower temp rise than the standard guage, which seems to jump to normal about 20 degrees C quicker than the new guage. The new one is also marked better and shows the temp sticking to around 83 degrees C most of the time, which is just on the opening temp of the thermostat.
