Turbo to a 2.4 hilux pick up?
  • Turbo to a 2.4 hilux pick up?
    Just a question to you wonderously wise and wobbly ones:
    Can you fit a 2.4 turbo to a normal 2.4 hilux pick up? Does anyone know if it can be done? Is it just too much hassle and not worth the effort?
    I am the friend of Hypno-Toad
    a
    a guy at my work bolted a 2.4 turbo on his 2.0 petrol the other day,,it worked fine lol i thought this was funny as he only used two manifold bolts loland was also running 20psi boost lol(by blocking the waste gate with nuts lol)
    as for yours im not sure but i dont see why not,,,,
      yes you can, looked to do it on my old pick up. Only thing was I was advised that with the extra load on the engine it might knock out a few bits
      My 4x4
      My choice
      Back off
        Is the fuel pump not different? The engine needs extra fuel to go with the extra air.
        You can take my 4x4 from me when you prize the keys from my cold, dead hand.
          are they the same compression ratio's ??
