Fan running all time is this normal??????
    Thanks guys i'll contact milner's and take a look at the stat first (sounds easyer)
    What do you mean by pluged matrix??????
    Regards
    Kev.
    2.4 black beast
      Matrix blocked..
      The matrix gets full of crud and needs flushing in the same way as the rad from time to time.. it basically means that the coolant cant get around the matrix to warm the air flowing through the fans
      Its not too difficult to do... you need to take the pipes going into and out of the matrix (by the bulkhead) and flush them with a hose pipe or airline
        Thanks mate, picture would be great as i havn't got a clue what one looks like.
        Regards
        Kev.
        2.4 black beast
          Been in touch with milner, currently out of stock.
          Awaiting one being sent on as soon as they arrive.
          Regards
          Kev.
          2.4 black beast
            Re
            I did my front and rear today, again!
            The rear one was clear but one of the thin metal pipes was totally and utterly blocked full of gunk!
            I cleared it by getting a brake cable off my daughter's bicycle and attaching it to a drill!
            Hey presto!
            A flexible cable that spins at high speed to clean the pipe!
            It went through it like a knife through butter!
            The whole coolant system is completely free of gunk now.
            When you get it clean you will not believe how hot the heaters get, they are boiling!
            My advice, fit new thermostat, fit new radiator cap, disconnect and clean the matrices, then the pipes!
            Gary
            Heater
              Marvelous!
              p.s. don't send your daughter down the hill to fetch a loaf of bread until you've replaced that brake cable!
                Marvelous!
                LOL!
                  Ok, so on my 1990 Surf imported from Japan (to Canada) I have the fan in front of the rad on the driver's side. However, as seen below in the picture, I have two wires that used to be connected to a piece of metal that is attached to the rad. Anyone know what these wires are for? They attach to that big conduit that then runs back to the fan.
                  Thanks,
                  Wes
                  • #24
                    I'm just guessing here, but they could be the wires that were attatched to a sensor that switches the auxillary fan on when the engine temp gets higher than normal.
                    • #25
                      hi its ur rad switch costs around £50 for new one had same prob but ok now
