oil guage
  • oil guage
    the oil guage on my 91 2.4 turbo reads just under half way when you turn on the ignition then after a fer seconds it falls back to zero. When the engine is running it reads zero. Is this correct or what should I do about it?
    caution please before carring out instructions
    Going back a few years [yes I’m old]
    And if memory is correct the it could be driven by resistance if so then if you were to take off the wire and short to earth it should go to max on the gauge and min when left open circuit. Ask around before you try it out just in case [no g/tee with this advice]
      my oil gauge stays just under half way? is this normal?
      9/11 WAS AN INSIDE JOB!
        Yep, thats just about normal. The needle sits at the 1/4 mark at idle then raises to around the halfway mark when driving.
          Check it's still connected at the sensor. It's on the oil cooler housing towards the rear, back from the oil filter and a little lower if I remember correctly. A little difficult to see because of exhaust.
          Nev
            Correct.
            Nev
