fault code 10
  • fault code 10
    Hi all
    i have a 2.4 2lt engine and just got a fault code ten off it says on here thats the starter switch, can anyone tell me what a starter switch is?
    its turning over fine but is taking a little while to start from cold
    Sta
    found out what the fault code 10, start switch, STA circuit is so if anyone else has probs this pic should help.
    diagram isn,t for a surf but gives you the idea
      Mines been a bugger in the cold to start too, i tested the heat plug timer and asked myself is prolonged cold starting with 2 batteries gonna do much harm?
      Then i took up the slack on the throttle cable and tried to start it with foot to the floor (just like an old Gardner engine) n she fires up a treat in about 7 seconds.
