I have a 92 hilux surf and wanted to transform the old straight body shape to give it a bit of a make over. Is it possible to put wheel flares straight onto the current body or do I have to replace the Panels and stuff?
92 surf - can I fit modern flares
I thought the cap was bent on the newer models
I thought the cap had a bend in it in the newer models with flares. Do I need to cut the guard after I install the flare so it doesnt stand out.
Does anyone know where I can order these flares in Australia or safely overseas?
I know that your in Oz m8 but have a look at these.
http://www.toyotahilux.com/index.php?doc=11&cid=386
They look good if you colour code them in
poppy
may be an outlet for these type in Oz some where ?
GOT NO COWBOYS HERE?
