Ok,so I get the engine running on this 1986 and there is a coolant leak coming from the cold start enrichment device on the side of the injection pump!The manual calls it a Thermo wax unit.Are these repairable?,If not where could I source one?,Are they a straight bolt on or is there something in the pump that needs to be timed to reinstall??Thanks..
2.4 coolant leak
Not sure if they are repairable, is it just seal or o-ring leaking? but if you have trouble get a new bit from Toyota we might have better luck over here. A chassis no and engine type would make things easier.
There is no sign of one or any coolant connections on any of the 2LT or 2TL/E pumps I have here. Got pics??4x4toys.co.uk - Keeping you on and off the road...
