Knackered rear window!
  • Knackered rear window!
    Hello,
    The tail gate window won't go up or down.
    The motor makes the usual noises if the key is used in the tailgate or if the interior dash switch is operated.
    I have removed the carpet and steel panel on the tailgate to check - nothing is moving.
    If its the small servo, does anyone know how to dismantle it, and where could I get a replacement (I don't want to take one out of the doors)
    Andrew
    Your rear window
    Hi, you have probably sorted the rear window by now but if not view cr15 posting on the 17th January!!
    Originally posted by The Lovely Boyo
    Hello,
    Andrew
