'91 2.4td Surf door window seals
  • '91 2.4td Surf door window seals
    Hello all.
    Does anyone know of some[where|one] other than Toyota that stocks new door window seals, ( the one around the sides and top edge of the glass) ? Drivers side front and rear are somewhat the worse for wear.
    Cheers,
    Matt
    I take it the deafening silence means that this is a Toyota dealer specific item then.
    Cheers,
    Matt
      We might have some 2nd hand ones - I will check tonight - but as for new ones I've only seen them at Toyota.
      Linda
      www.4x4toys.co.uk
        Thanks. That would be lovely if you could have a look, (when convenient). As long as they are in decent nick, second hand are fine. If you have a full set, that would be even better.
        Thanks very much,
        Matt
          Thanks very much,
          Matt
          Its dark and cold so I will have Tony check tomorrow morning :wimp: :shiver:
          Linda
          www.4x4toys.co.uk
            Apologies for my belated reply. Any luck?
            Thanks once again,
            Matt
