hi all, hopeing someone can help me out here.
i have removed the heater matrix (what a bu??er of a job that was!!) stripped down the air box and removed the heat exchanger (the radiator type thing) i can not see any damage to it, although the heater box was full of coolant so i know it's been leaking from some where.
is there any way of testing it for leaks? i have removed all the fluid, plugged up one of the inlet pipes, submersed it in water and blew down the other inlet in hope i might see some bubbles appear from some where, but nothing! it just builds up the pressure. i know it's under a greater pressure when fitted so may be ive not got enough breath!!
any ideas would be a great help. if not, does any one know if the dealer's sell just the heat exchanger and roughly how much?
many thanks
andy crofts
p.s. dreading putting it all back together again!!
many thanks
andy crofts
