Radio !
  • Radio !
    Hi all,
    My 93 ssr-x has had a CARROZZERIA stereo fitted at some stage of its life, now this stereo looks the nuts, but thats all its got going for it !
    I have got a new stereo to fit, but would like some ideas how to get the old one out ? .
    CHEERS
    NOSHER.
    Originally posted by nosher
    Hi all,
    CHEERS
    NOSHER.
    You will need to remove the dash... Look at this website to see how:-
    www.showmesome.info
    I can't get into it at the moment to put a link to the right place... when u get onto it look at dash removal
    Once you get the dash off the existing radio will be bolted in. just take the bolts out and your done..
    repeat the process to put back in.
    if you currently have a jap spec radio you will also need a radio loom convertor (to make the wiring fir without cutting etc) these are availible form the forum shop
    Joe
    Paranoid? They're out to GET YOU!
      Heres the wiring colour codes for ya as well....
      http://installdoctor.com/Harnesses/Toyota-Wiring.pdf
        Vince,
        Will the 92 ln130 be the same colour wires (typically of course)
        Cheers Mate
          www.showmesome.info
          Joe
          Thanks for the info Joe, i have the loom convertor already so its all systems go , i will try to change the radio this afternoon.
          Many thanks again for help,
          NOSHER
            Vince,
            Cheers Mate
            Yep, that is the wiring codes I used and they will be the same as yours.
              Thats my job sorted for the weekend... I only have the CB to listen to at the mo (and thats not much fun with all the idiots you get on in m'cr!)
              the pillocks who fitted the alarm and stereo (not mentioning any names SSSSHHHH!! Tranzfit / Transfit / Tranz/s Parts SSSHHHH!! They use all them names! completely naffed up the job.. didn't put the dash back together properly and only connected one speaker... needless to say i paid nothing for fitting, i refused point blank,
              I'm gonna sort it out sat/sun so now atleast it'll be a lot quicker now i know what wire is what
              Cheers Mate!
                NOSHER
                here you are mate... got the right links now
                http://www.showmesome.info/hilux/workshop/dash3.htm - dash remival
                http://www.showmesome.info/hilux/workshop/door_card.htm - fitting door speakers
                http://www.showmesome.info/hilux/workshop/stereo.htm - fitting stereo
