glow plug not recieving any power and have been told its most likely my relay, if anyone thinks different i would like to know, been to main dealer and they want 88 quid for new relay, anyone know where i can get one cheaper than this???????????
need a glow plug relay
Originally posted by caseyjglow plug not recieving any power and have been told its most likely my relay, if anyone thinks different i would like to know, been to main dealer and they want 88 quid for new relay, anyone know where i can get one cheaper than this???????????
'most likely' seems a very open description of a fault, assuming the fuse has been checked and checked for voltage to the relay????????????????????Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
Originally posted by caseyjreplaced relay but still wont start, anyone got any ideas
What does urs do?
Originally posted by tigerbuc2004This sounds familiar am keeping an eye on this thread, does yours turn over but not fire? Mine does that at times, its not a fix to your prob but if mine will turn over but not start i turn the ignition off and on a couple of times then she fires up. I am really confused.
What does urs do?
Originally posted by caseyjsome one must of had this problem before, need to fix before sunday to tow the boat, please help
crack open the injectors and check theres fuel to each one. I would say that if your getting voltage to the plugs then it could be fuel related, anyway don't think its been cold enough not to start without the plugs working. So if your sure the glow plug side is OK then its probably down to fuel, fuel pump, fuel filter etc.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
