Hope someone can help! My rear window wont go back up is there a way to work the mec so it will return to the up position?
Help Windows
hi have you pressed the window lock button on the drivers door just under the mirror switch or it may be on the centre consolOriginally posted by SandstormHope someone can help! My rear window wont go back up is there a way to work the mec so it will return to the up position?https://www.facebook.com/groups/henpals/
is that with key and button, is wiper seated correctlyOriginally posted by stormforce1067hi have you pressed the window lock button on the drivers door just under the mirror switch or it may be on the centre consolSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
