glow plug info required
  • glow plug info required
    Can anyone tell me wot are the best glow plugs to use, I have just replaced mine as i have had trouble with starting with NKG plugs but still having trouble. Starts ok with easy start so this leads me to think its still the plugs. Can anyone confirm this or has anyone any other ideas? ps has anyone heard of Hot Spot plugs and where to get them from.
    Hi Jubarink!
    Welcome to the forum - you'll find that 99% of members here are completely mad, but you'll also find that this is forum is like Carlsberg lager, i.e. probably the best in the world (for Surf info anyhow).
    Unfortunately I don't know the answer to your thought provoking question, but if you try doing a search on Glow Plugs you may find some enlightenment. You'll probably also find loads of info re Chillitt's shed , but there ya go.
    Hope you find the answer. You'll have to let us know how you go on. I'm on the verge of buying some Glow Plugs myself.
    Rob
    Constantly Striving to Attain Lower Standards
      Hi Newbie!
      Glow plugs for sale here, I use them and I think a lot of others do too,
      well exept Nednil obviously LOL.
      http://www.milneroffroad.com/LN130.htm
        Hi rob, Thanks for taking the time to answer, I have done a search as you said, But can't find anyone that actually names names....
        Hopefully someone somewhere somehow will be able to help.
        thanks anyway
        julie
          Hi Newbie!
          Thanks for that, Great price...I paid 11.60 each for **** NKG's...
            thanks anyway
            julie
            Hi Julie, you might also want to try RoughTrax. If you're looking for specific advice you can speak to Barry there. He's always really friendly and helpful, and knows his stuff.
            Rob
              Rob
              Would also check glow plug fuse is OK. How long you leaving it before turning the key, could also be glow plug relay.
              My 4x4
              My choice
              Back off
                Thanks for that, but had a sparky check through wires and fuses etc, not on normal relay, been rewired so on manual button inside car, but its all ok, power to all bits that need it anyway.
