After haveing the head fixed this month, the fuel pump has decided to give up. It is p*ssing fuel out when cold, so I am guessing the top gasket has gone, but now the ECU has come up with fault code 12, and the truck is undriveable.
So.... Can somebody point out on this picture where the Timer Control Valve is.
I need to get the car home, which is 30 miles away, if I disconnect the Timer control valve, will it drive?
Also, is it possible to change the gaskets without removing the pump, if not, how big a job is it to swap the pump for one from a breaker, (presuming I can get one).
