ive recently bought a 1993 surf .. my prob is that it wont select 4wd but i can hear the relay clicking when i am pushing the button .... any advice anyone on here can give me ..cheers ..
4wd wont engage
Originally posted by gruntive recently bought a 1993 surf .. my prob is that it wont select 4wd but i can hear the relay clicking when i am pushing the button .... any advice anyone on here can give me ..cheers ..
Nevillef_________________
Nevillef
You say that you can hear the solenoid clicking, have you tried pressing the gas pedal and moving forwards? as doing this engages 4 wheel drive.
p.s. Hello Newbie, welcome aboard!
no green light comes on on dash and no it dont go into 4x4.....the click i am hearing is behind the panel in front of the gear stick (automatic)... i stripped it out and it seems to be some kind of fancy unit ... i dont know how it works with it being electrical and not manual (that i am used to) but is there a throw type mechanism on the gearbox that could be stuck with lack of use ? ......
Originally posted by grunti will mate .. but curiosity is getting the better of me .. whats the fuse for ?
Rather than me trying to explain, it would probably be quicker for you to read this thread.
http://www.yotasurf.co.uk/forums/sho...ht=4x4+problem
i get the jeep back next week.. its in the process of getting a new engine fitted which i purchased from nippon jap spares .. the other engine developed a serious rattle which sounded like it was in the top end but after getting it stripped indicated to be bottom end so i went down the road of fitting a replacement motor with 33.000 miles .. so once i get it back ill check the fuse ... ill keep you posted cheers .....
