Radiator or fan cover
  • Radiator or fan cover
    Hi,
    My garage has told me that my Surf 2.4 td radiator/fan should have a cowling over it to direct the air from the fan to the rad. Is this standard on surfs? I have a 1990 surf and don't have a radiator cowling as he described.
    Would anyone know where I could pick one up relatively cheaply?
    Thanks in anticipation,
    Gaz
    Yeah, it helps the fan pull air though the rad. otherwise air just blows around the fan. We often leave the bottem half off, as it just collects mud and blocks the mud if you offroad alot. But both peices are better.
    I have a shroud (somewhere) if you're interested in a used one.
      Thanks Tony,
      I've sent an email about this to you - I'd be interested in taking that from you. Can you get back to me pls?
      Gaz
