have no power going to cold start on fuel pump, have power going to sloilnd , but when run live to the cold start it starts but revs right up and smokes loads but when you take live off cuts out HELP HELP!!!!!!!!!!
no fuel
fuel
hi have you tried the obvious like fuel at the filter head,if not try pumping hand primer on top of filter head until it goes hard.if you have trouble getting fuel up to the filter then check fuel lines from tank could be split or broken,also check filter to make sure its not blocked.hope this helps.Originally posted by mat1212really need help my 2.4 efi has no fuel going to it i thought it was pump changed it but no change? please helpwww.overfab.uk
