termostats
  • termostats
    any info on stats i want mine to run cooler
    mine is too hot to handle
    any one out there that knows what temp range stats are avail in
    when im climbing big hills(lots in wales) while towing temp gauge climes quicker than the smurf but soon as it hits the red area it dpos back to normal prety quickly
    HELP
      try a search on towing / overheating transmission, i reckon you needs an oil cooler
      it's in me shed, mate.
        im hopin the oil cooler is not needed as the temp gauge drops i thought if auto box was overheating everthing would just get hotter
        ta for the reply
        john
          yours is doing exactly the same as mine...
          every one says fit an oil cooler!
          i tried converting the aircon rad, and failed. so im off towing till i can work up some enthusiasm for spending some hard earned..
          if you discover anything else, do be sure to post it.. (but only if its a cheap fix!)
            I have fitted quite a big oil cooler and it did get hot once on a 2 mile hill (not towing much weight but lots of drag) so i am not sure whats up unless i gave it too much welly on the hill? I WAS DOING 30MPH!!!
            Tim
