can anyone help---- after recently replacing torque converter and flexi plate due to the old flexi plate dissintergrating i've refilled the tranny but have put less in than was drained out and is reading above normal and have no drive through the box not even reverse which i should be able to get even if the seals had gone any pointers would be greatly appreciated
help auto box problems
The transmisson fluid must be properly filled or you will get drive problems. Make sure the Hi-Lo lever isn't stuck between positions (done that a few times!)Originally posted by smokeyjoecan anyone help---- after recently replacing torque converter and flexi plate due to the old flexi plate dissintergrating i've refilled the tranny but have put less in than was drained out and is reading above normal and have no drive through the box not even reverse which i should be able to get even if the seals had gone any pointers would be greatly appreciated
Nevillef
THANKS HAVE A FEELING IT'S THE TRANNY PUMP GONNA TAKE THE FEEDS OFF THE COOLER TO C IF IT'S PUMPINGOriginally posted by laser_jock99The transmisson fluid must be properly filled or you will get drive problems. Make sure the Hi-Lo lever isn't stuck between positions (done that a few times!)
Nevillef
yes mate tried everything-- taken feed hoses off cooler -not pumping,so gonna take it to a tranny specialist, and thanks to everyone for their suggestions keep ona trukin'Originally posted by kevbdid you check the level with the engine running???
move the lever into all gears and then put back in park and check level(with engine running)
