Help
  • Help
    just found out that my fly-wheel as gone on my
    1993 2.4td surf,could anyone tell the best place to get
    a replacement and how long it should take my local garage
    to replace it,also any tips to make his job easier,
    any info greatfully recieved thanks craig
    It no different to any other car, just an extra propshaft to remove, and a heavier gearbox! It makes things easier to split the t/case from the gearbox first.
    Look at the usual suspects, Milners, roughtrax, etc, you can get another dual mass flywheel to replace it or get a UK spec normal flywheel and clutch. whatever works out cheaper.
      thanks for that,will they need a spiecal flywheel puller?
