9 Miles To The Gallon
  • 9 Miles To The Gallon
    Help Can Anyone Tell Me What I Should Be Getting To The Gallon,.
    At The Mo I Get About 9 To The Gallon.
    Thats Normal Driving A And B Roads (not Towing).
    I Pulls Find But Does Shake Alot At Bout 45 To 60mph
    I Find I Get 173 Miles To £40 Of Deisel
    I Have A 2.4 Surf Auto 1993-k
    Please Help If You Can
    Blimey!!! I do the same driving as you, mostly B roads and a few A roads, and I'm getting about 22 mpg.
    I think you should look at an air and fuel filter change first, followed by getting your tracking checked to try and cure the 'shaking ' prob.
    Also check your tyre pressures, should be about 33 psi al round. and get some Redex fuel injector cleaner in yer tank.
      I'd be checking that i was in high ratio !!!!!!!!!
      Laugh!!! I nearly bought my own beer.
      Paul
        Just thought 173 miles to £40 derv = about 17 mpg
        Paul
          hey that even makes mine look good
          sell yours and buy a petrol one
            As far as you wobbles go, my wobbles and handling probelms were cured with a new set of rear tyres, getting the Front Wheels balanced and setting the pressure in all tyres to 30 psi. Runs ve smooth now, as far as the consumption!! I am up and down the hills in rural Cork (I mean C road UK style) I still manage a respectable 24 mpg (33 mph at 65-70mph) on the UK motorways.
            I'd get your jeep serviced if I were you and check all of your plastic airpipes coming from the airfilter to the Turbo etc.
            You may be pleasantly surprised.
            I am the friend of Hypno-Toad
              Ok Thanks People
              Iwill Get It Looked At
              Cheers Dan
                Ok Thanks People
                Cheers Dan
                Out of interest, what happened in the end?! Did you get the consumption and shakes / wobbles all sorted? I'm interested because I recently became a Surf owner and am just getting used to everything about the vehicle. Interested in tyre pressures, balancing, consumption, etc.
                Let me know, cheers
                Mike
                  I was amazed at the 37 mpg I was getting - until I discovered the speedo had been converted to mph but the odometer was still reading kms.
                  Fear of death is the beginning of slavery
                    Very good! At least 23 or so MPG is far better than 9!!
