Towing Weight
  • Towing Weight
    Does anyone have a rough idea what the max towing weight (gross) is for a 2.4 surf?
    Chris
    I am the friend of Hypno-Toad
    If I remember right the Aussies have it pegged at 1.5 tonne. I think I've heard it mentioned in this country at 2.5 tonne. Your best bet would be to ask the company who fit the tow bar, the general rule of thumb is approx 85% kerbweight of your vehicle, with 100% for experianced towers.
    Also check out the towing thread in the basement, as Marky has loaded that with very useful information.
    Gone from 4x4 to 1x2
      Chris
      Have a look here
      Maurice
        Cheers Chaps managed to tow three aplacas and an antique horse box with the brake on (Naaaa Idiot) for about 170 miles up hill and down dale across Ireland. I did think it felt a tad underpowered but leaving the brake on the trailer will have that effect
          Originally posted by Morr
          Have a look here
          The 4Runner figures given on Morr's link are wrong.
          I have in front of me a Toyota (UK) 4Runner brochure from June 1995.
          The towing capacity (with a braked trailer) is 2200 kg or 4849 lbs
            Sorry, those figures were taken from a post on here, I'll get em updated shortly.
            Maurice
              should also be on the plate on the tow bar?
              isn't it?
              might be wrong!...
              someone go look!
                Now changed.
                Maurice
                  Interestingly, on my tow bar it says max UK towing weight 2200 kg, max manufacturers towing weight 2430 kg.
                  I've towed 3000kg with mine, but it made the clutch slip a bit, although it went well on the motorway
                    isn't it?
                    might be wrong!...
                    someone go look!
                    A lot of towbars give the MAX load that the tow-ball etc can handle.
                      this is what i dont get about the towing rules
                      surely you are breaking the law if you tow the reccomended 2200kg as it is more than 100% of the vehicles weight?
                        Landrovers are the same,
                        Disco 3 TDV6 Auto:
                        Kerb weight 2718kg
                        Gross weight 3230kg
                        Max Towing Cap. 3500kg
                        I don't understand the current laws about towing either, hope i don't get pulled up while i'm towing.
                        =SOLD UP!=
