My A/C as stopped working I put it on for the first time this year the engine note changed but on cold air ! it worked ok last time it was use(last summer) any ideas ?
air con
It may be that it need to be re-pressurised as the gas can leak out if not used for a long time, they say it should be use at least once a month.Originally posted by gonzo9112My A/C as stopped working I put it on for the first time this year the engine note changed but on cold air ! it worked ok last time it was use(last summer) any ideas ?
If not that it may be the compresser or condenser is broken which can be quite expensive. If you look under the bonnet and get someone to turn the a/c on and off you should hear the motor going, this at least will tell you if its seized or not. Best to pop it in to a local aircon specialist they will be able to check it quite quickly.
SteveSteve
Born to be wild!!
No but try to catch a fridge engineer at work (well on tea break) and ask him he will at leat give you a good idea and not rip ypu off as will a car dealer sort of bloke!!Originally posted by gonzo9112Thanks for the info can anyone recommend a good aircon specialist in Nottingham?
I know what I am talking about note the e'mail address......any other help on this matter then contact me direct?
Keep surfin....
Actually, you'll need to have the engine idling to do this - the compressor comes on by means of an electrically actuated clutch on the pulley, so when it is on, you should be able to see the compressor shaft turning with the pulley - when it is off, only the pulley is going round.Originally posted by mudhogIf you look under the bonnet and get someone to turn the a/c on and off you should hear the motor going, this at least will tell you if its seized or not.
Steve
If its right out of gas, a low pressure switch prevents the clutch actuating.
Running it once a week, even in winter is generally enough to prevent nasty surprises in the Spring - unless you are unlucky enough to get a stone in the a/c condenser. Its also the best way to demist ona foggy wet cold morning as it dries the incoming air.
Shoudl be easy enough to find a specialist in Nottingham.
Kev
fluid level in A/C system
Anyone no how i can check A/C fluid level, as it has stopped working. Relay klicking in, but no movment from condenser/pump unit. Guessing its that low fuid cut off sensor thats on them.
Yea, so if anyone knows how or has an A/C system diagram they can post, that would be helpfull.
