I know the steering wobbles be covered in detail, and I have had a look through the previous posts....
The trouble with mine has come on pretty instantly..
The steeing wheel is wobbling at all speeds - the wobble is faster the faster you go.
The truck is also pulling a reasonable amount to the left, also pulls to the left when you brake, although not sure if its the same pull or not.
It "seems" like there is more brake dust on the passenger front wheel than the driver front wheel too....
I know what it could be, but my suspision is a siezed caliper??
I just dont want to waste time etc.. getting tracking / balancing done if its unlikely that its that.
What do you lot think...
I'm thinking if its come on suddenly its unlikely to be the idler arm / steering setup / bushes etc.. does that follow logic?
CM
CM
