Water pump
  • Water pump
    quick question
    mechanic is changing water pump and thinks he is after losing a washer from between the fan coupling and water pump pulley. Can’t find the washer on any parts diagram. Is there ment to be a washer there or not
    as far as i can see there is no washer between the coupling and the fan etc
    the pulley slides on the waterpump and the fan assembly and 4 nuts tightens it up
      Thanks taught so
