1990 2.4 td surf 120km, developes a creaking noise when warmed up when you press the clutch pedal up and down. I have greased pedal and push rod. Have also greased push rod on slave servo next to gearbox. Had a second oppinion but still not sure wheather to replace slave cylinder or look in engine compartment on other side of clutch pedal.
Its getting noisier and wondered if anyone has had similar problem.
Any comments appreciated.
Regards, Neil
Regards, Neil
