Central Locking Question
  • Central Locking Question
    Hi All
    My Central locking has got very slow.. I turn the key in the drivers door and instead of locking all it only locks mine ...If I hold the key in the lock position then eventually the other doors lock. They used to all lock straight away.
    Is there any lube points to help or is it somthing else??
    Thanks for any help
    Mark
    I have wd40 all locks and still no better.
    The in car door lock button has them locking up and down fine.
    Any idea what the key does different to the button and how do you get to it to sort it out??
    Mark
      I’ve done the 50/50 and phoned a friend you guys are my last hope by asking the audience
      any hints??
      Mark
        Central Locking Problem
        If, as you say, it all works OK from the interior door switch then most likely cause could be connections on back of the keyswitch or the keyswitch itself.
        The URL below will show you how to remove the door liner to access the keyswitch and all the other connections on the door arm.
        http://www.showmesome.info/hilux/workshop/door_card.htm
        Nil Illigitimi Carborundum
