Have discovered a slight misfire when feathering the throttle on at approx 2k. My first thoughts were injectors possibly faulty, but thought id run it past you guys first. Its a 2-LT.
Misfire
Most surfs do this, it has been explained on here before but it isnt anything to panic about, if you really want to hear something to panic you, hold it at 2k revs under no load ie in park, you will think the engine is about to rattle apart, all you are getting is that same noise/effect just not quite so bad.If it aint broke...........give it some more abuse!!!!!!!!
I gave it some abuse.................and it broke!!!!!!!
