Hi all
Anyone know the allowable head/block tolerances on a 2.4TD? (microns or thou). I've got a new head but want to make sure there's no warping on the block (unlikely I know). Seems like I've also had a pressure leak path under head gasket at cylinder 4 (surface pitting) on block.
Rather than remove the block and skim it, anyone know and allowable depth/width in a pitted surface that the gasket will accomodate?
The only other way I can think to prevent future leak (other than skimming block or replace engine) is gasket paste or head crack sealing compound. I know Holts do a crack seal compound?
Any suggestions or experiences greatly appreciated.
[SIZE=4][FONT=Century Gothic]I can fix it...it won't be cheap.........or pretty![/FONT][/SIZE]
