Getting there with this head removal, but now I'm stumped as to how to actually reach the inlet manifold bolts - this is the current state of the engine bay (http://www.jameskett.dsl.pipex.com/engcur.JPG) so how on earth can I reach most of these bolts?
HOWEVER, before I remove all these complicated parts, I noticed that the rubber bottom of the pressure cap has a few small chips out of the edges - seeing as the only symptoms my Surf had were pumping out a little coolant from the reservoir after an uphill run (doesn't overheat at idle, no mayo, no steam etc...) is it possible that the presure cap could just be letting hot water into the expansion bottle too soon and therefore overflowing it? The thermostat tests just fine (opening around 80 to 90 degrees). I'd like to be sure before I finally remove the head.
As a final question, can I get hold of a manual from somewhere that actually relates to the imported 2.4TD Surf?
thanks
James
thanks
James
