Ive just got a regular supply of dirty cooking oil. Can anyone tell me the easiest method of filtering it thats effective. Cheers
oil filtering
when driving around if you see a yellow SAFETYKLEEN van chat him up for some of his degreaser unit filters they go down to 2micronsOriginally posted by jonnyq462Ive just got a regular supply of dirty cooking oil. Can anyone tell me the easiest method of filtering it thats effective. CheersEnjoying Life after Cancer
Pops
I believe you need to warm the oil to get it thin enough to pass through the filter. I think people have used hot water tanks with immersion heaters for this job.
Kev
The oil should be filtered to arounf 5 microns, otherwise you'll find your main fuel filter blocking regularly. It will have to be heated to get it thru filters this fine.Originally posted by exmee46I believe you need to warm the oil to get it thin enough to pass through the filter. I think people have used hot water tanks with immersion heaters for this job.
Kev
There are other items you should do when using waste oil, have a look here for some further info and links to other sites to check out.Maurice
