so getting no diesel to injectors have noticed when i hand prime pump it comes up hard then a minute later it soft again cant see any diesel leaking out anywhere so whats the problem or is this normal also on the kzn130 theres no relay for spill valve its run from the ecu have now replaced the primer still no go have checked for faults and just constant flash on engine light meaning no faults im fked dont know where to look next or could it be in ignition any thoughts
No Diesel
Don't know who would do it in your area, but I recently found out that is difficult to get the flywheel in UK, at the end I bought it from Spain, on this website [url]https://www.euro4x4parts.com/en[/url]the wolf is always bigger when you are scared!!
- 1 like
Hi budweiser, yes a heck of a job! Everywhere I tried appeared to be out of stock and no replenishment information in sight.
I'll check that URL you've posted and many thanks for that, but all being well there's a very good used flywheel and kit package about to be posted to me.
It's all about finding the skill to undertake the job because I'll happily admit, that skill doesn't sit with me!
- 1 like
Rembuntu so i gather you are talkiing about your spill valve on top of injector pump i would pull the ecu out open it up and have a look if anything is burnt out usually the capasitors leak meaning there fked and check the copper traces sometimes they burn out
