Hi.kzn 130 95 gen2.have fitted a new brake load compensating valve but the bracket with the two long studs that secures it is adjustable .can slide vertically approx 10mm. Is there a correct position on a standard vehicle. Ie. Is there a measurement guide. In the top of its slot this would reduce braking effect. So do u adjust to a central position . Any ideas.
Brake load compensating valve. Correct position ?
