hi everyone! i'm a new surf owner. got my surf from japan. it's a third gen kzn-185 surf ssr-x 3 liter manual tranny. my problem is when i purchased my surf the steering wheel was replaced by previous owner with momo. i've noticed that the airbag light wont shut off. i presumed that because the steering wheel was replaced, the driver side airbag is gone. so how can i disable the light? sometimes its a bit disturbing. any sugestions will be very much appreciated. and how can i check the passenger side airbag if its working? thanks
AIRBAG light won't turn off
That light stays on when it detects that one or both of the airbags are disconnected. Don't know if system remains active if only one is disconnected though. Don't know how to test airbags either! If you really want to stop the light i suppose you could take the bulb out.
dead easy mate just pull dash cluster out and remove bulbfrom behindOriginally posted by litolhi everyone! i'm a new surf owner. got my surf from japan. it's a third gen kzn-185 surf ssr-x 3 liter manual tranny. my problem is when i purchased my surf the steering wheel was replaced by previous owner with momo. i've noticed that the airbag light wont shut off. i presumed that because the steering wheel was replaced, the driver side airbag is gone. so how can i disable the light? sometimes its a bit disturbing. any sugestions will be very much appreciated. and how can i check the passenger side airbag if its working? thanks
I,LL GO FIRST NO PROB
(i also juggle dynamite)
woops forgot to explain with part of srs system removed it,s the only to disable unwanted warning lightOriginally posted by stimpy30dead easy mate just pull dash cluster out and remove bulbfrom behind
I would get it checked out at a dealer as the passenger air bag may be disabled or have a fault. Removing the bulb would simply hide any faults in future with the other air bag. It might be just a case that Toyota need to reset the srs system on a diagnostic tool and all will be fine. I would ask for their opinion if I were you.
Andy
