Help
  • Help
    have just ripped out dash to replace speedo fascia
    only thing i cant do is pull off the needle
    should it be tight or am i missing something?
    ex Burgundy 2.4 owner
    It should pull off, use a FORK to get behind needle then gently pull
      Yes they are very tight, best thing to use is a kitchen fork as a lever, and make sure you have some super glue handy.
        cheers
        will finish it after countdown( sad i know)
          all back on
          however dash warning light t belt now comes on is this related to me changing the fascia?
            Yes & No !!!!!!
            I.ve done 6 now & with 3 of them the T belt light came on, but not with the other three.
            Those which did not come on were below 90,000 Kms, the ones which came on were over 90,000 km's ?????????????????
            [FONT=Franklin Gothic Medium][COLOR=Magenta][SIZE=2][B]SEWERAT BOB[/B][/SIZE][/COLOR][/FONT]
            [SIZE=3][COLOR=SeaGreen][I][COLOR=Lime][B]I just sit here & looks out to sea or if i'm really rushed then i just sits here & continues to look out to sea[/B][/COLOR][/I][/COLOR][/SIZE]
              can i reset it?
              and if so how?
                Reset button recessed behind a rubber grommet just below speedo. Just press the button with a matchstick to reset.
                It's only a hobby!
                  cheers
                    NO!!!... use a cocktail stick!
                      to late i used a match
                        I used a paper clip
                        It's only a hobby!
