Is an engine and gearbox from a FWD car any good for a RWD/4WD car?
Non Surf Related Stupid Question
Originally posted by kitesurf_philIs an engine and gearbox from a FWD car any good for a RWD/4WD car?
Depends on the engine - ford ones can be converted with a new belhousing I think but you will need a new gearbox.
I think Renault engines from earlier FWD can be converted but again on these the gearbox is normally in front of the engine so you need to modify the gearbox to reverse the direction of the output shaft.
CheersIt's only a hobby!
Originally posted by *Turandot*Unfortunately it doesnt work like that. If you have a centre differential it has to be a particular type of limited slip diff. If it isn't losing traction on one wheel will disable all 4.
If you want to use both the outputs from a FWD gearbox you have to weld up the internal diff.It's only a hobby!
A Series engines were used in both Moggy Minors and Minis, like someone selse said its mainly down to the gearbox - old Saabs used to have a RWD Triumph based engine runng a FWD setup with the gearbox underneath acting as a sump (like a Mini!). A buggy with rear wheel drive and welded up diff would be far more fun than a 4wd one, my Stock Car uses a welded diff and it loves to go sideways.Cheers
Mart 870
Racing for Thomas
Originally posted by da SLUG manshould have gone for the XR4x4 then!
Another mate just blew the engine in his and may scrap the car , so all transmission bits are OK , just need a lump , and I know where one is .
RickRick...Member of 1st Gen club. ONE LIFE ... GET ONE !!
Quote:
usually uses a diff lock not LSD
Why would you need a diff if it wasn't a limited slip one? Think about it!
Originally posted by BUSHWHACKERI've seen a few Vauxhall DOHC 16v engines used in Caterham/lotus7 type kit cars, so I guess it can be done quite easily
Vince.
You'd have to use Land Rover style axles that have the diffs on the same side of the car, and a transverse engine would be way over to one side to make the drive shafts line up. The gearbox diff would be the biggest problem, can't think of any FWD cars that come with a diff lock, without one your wasting your time unless you can weld it up.
Have a look at some of the mid/rear engine Comp Safari cars, and see how they are set up.4x4toys.co.uk - Keeping you on and off the road...
