concise spot light wiring guide please?
  • concise spot light wiring guide please?
    Have read the previous posts re spots - but wish a little more detail.
    Can someone please advise / draw me a picture!! .
    Want to wire 2 spots to front of car.
    Have fog light switch not being used next to rear window switch - want to use this if poss.
    Can I somehow use the fog light wires that are sitting unused in the bonnet?
    I appreciate they will be on dipped beam - can I easily get around this.
    Would be lovely to do all the wiring in the bonnet rather than start ripping the inside apart.
    Thanks in advance
    Paul
    .......because I can....OK!
    2.4 TD manual 1992 SSR-X
    Thanks in advance
    Paul
    Check your mail box I have PM'd you with a contact number
    NO WORRIES!
    Rusty
      thanks for advice.
      but..... which battery do I take the main feed off of, or doesn't it matter please??
        thanks for advice.
        Hmmmm I shouldn't think it matters but it probably would be better to take it from the ancillary battery (not sure which one this is as the 'runner only has 1 battery)
        NO WORRIES!
        Rusty
