As you know I have a SSR - G model surf that needs work doing to it , I put it in for a pre mot this morning and it needs welding to back axle if I was going to put on a tow bar on it which I want to do , other faults are , abs light on , oil leak from gear box and real axle and other run of the mull stuff , my predicament is that the body and interior are in pretty good condition also it's the light blue model and the 4x4 all works fine , I also have a green 3rd gen SSR - X which is in slightly better condition underneath, no welding needed , no leaks etc but the 4x4 system doesn't work so do I do up the blue one which is a higher spec model or use it as parts for the green one and try and change over the 4x4 , ps the blue one has approximately 175k miles and green one 145k miles , my gut feeling is the blue one which colour wise looks better but I don't know , any thoughts would be most welcome , thanks
