Egr removal
  • Egr removal
    Has anyone disconnected there egr and continue running there surf , I have a 2nd gen 3ltr surf which is putting out black smoke when driving also seems a little rough but drives spot on , just wondering if disconnecting the egr would help the black smoke , what do you think , thanks
    plenty have including mine although i didn't do it
    This chap mentions it in this very recent thread http://hiluxsurf.co.uk/showthread.php?t=84497
    best of luck
    Yes it's a V8, don't you know I'm loco?
      I just put a blanking plate in the side to the rear left of the engine (as you look at it). Left everything else "as is". I did it today, seems to bit a little bit more torquey.
        Took mine off altogether when I replaced the head. Runs fine without it, you don't need it in the uk.
          Done mine, seems to run just the same , only disconnected it as it rattled and was driving me mad !
            removed mine altogether and used a blanking kit of ebay and just blocked the pipe when i fitted an AMC head and it drives perfectly.
            Plus if i need to take the inlet manifold off its a lot easier
            GRAVITY IS A MYTH THE EARTH SUCKS!!!
              see this thread its got a little write up I did a while back about the EGR
              http://www.hiluxsurf.co.uk/showthrea...&highlight=egr
              My 4x4
              My choice
              Back off
                did mine sometime ago, removed and cleaned all the dirt of the manifold intake at same time, massive difference.
