tundra brake upgrade on a 94 surf
  • #31
    Originally posted by galooph View Post
    @budweiser - Have you been happy with the 13WL calipers on your 2nd gen? Any issues you've come across?
    yes, happy with them,
    the surf got 1" brake master cylinder, that im thinking i will fit a 1,16" of a Toyota T100, due i am nearly finished the rear disc/drum brakes
    • #32
      Going once, going twice...
      • #33
        Ok, the temptation is too much! I'll take them if nobody else has. I tried to PM you, but "J i m s t e r has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him"
        You can email me at my username @gmail.com
        Thanks,
        Dan
        https://galooph.com
        • #34
          Just in time Dan - I was going to post them back this morning!
          Will email you.
          • #35
            Do anybody knows why I can't see the pictures? (I didn't touched photobucket)
            • #36
              photobucket no longer allow hosted photos to be linked to websites unless you upgrade your account
              $400 ransom
              • #37
                #13.1
                robkeith commented
                5th May 2019, 09:33
                hi, where can i buy these brackets? or full detail on dimensions etc. so want to do this mod or even use the 338mm rotors rgds
                if yours is a second generation you need to make the brackets, that I made with the help of a friend engineer, if you have a 3rd generation you don't need brakets
                • robkeith
                  robkeith commented
                  Editing a comment
                  nah mine is secong gen, so need the bracket, although im looking at hummer h3 rotors as they have 100.7mm centre hole although 315mm diam not 319, do have drawing of the bracket? rgds
              • #38
                Several year later and t100 master cylinder, and no trouble at all
                • #39
                  Originally posted by Karma Supra View Post
                  Yup, and light trimming of the disc shield.
                  Edit: beaten to it!
                  As I always have the part numbers in one note:
                  Front Brakes:
                  Pads: 04465-35290
                  Squeal shim kit: 04945-35080
                  Caliper Rebuild Kit Front: 04479-60080
                  Pin clip x 4 47749-35040
                  Front Disk x 2 43512-0C011
                  discs are about £50 each from Toyota, at that price it's not worth shipping from the states! I just got a set of used calipers (13WL)and rebuilt.
                  Hey, hope you are keeping well, it's time to start thinking to replace the brake discs, do you have a part number? Thanks
                  • #40
                    well, after all this time, that im surprised that lasted so long, i need to replace the discs for first time since i build it
                    • #41
                      Glad to hear it's still going strong! Those discs have lasted well
                      https://galooph.com
                      • #42
                        I kept looking at them every year as a check, happy how long lasted, now I'm looking for new ones, but the ones are drilled and grooved but in black, any idea, or link for this? Thanks
                        • #43
                          I don't recall seeing any drilled or grooved discs for these, the genuine Toyota ones are just vented, I think.
                          Could always check on https://www.toyota-4runner.org, I know there's a lengthy thread on there about the brake upgrade/disc swap, so you might find part numbers for drilled/grooved disc options there.
                          https://galooph.com
                          • #44
                            Seems like they are available in Australia at least.
                            https://www.ebay.com.au/itm/13288593...4uf7DJxNjypGjb
                            Not really needed in my opinion. Standard vented work fine for me.
                            • #45
                              Thanks, yes I can get factory surf ones here, just looking for the tundra in black ( drilled and grooved)
