I give up
  • I give up
    What's the knack to removing CV joints off the drive shaft??
    pull the outer cv boot back, give the shaft a good clean under the boot with some rag and de greaser, then you should see an external circlip holding the cv to the shaft, remove the circlip and gently tap the cv off of the shaft.
    www.overfab.uk
      Is this coomon to all? It's the XC I'm doing, can't see where the circlip would go on the new one.
        Andy the circlip is on the shaft. put the drive shaft in a vice,cut off or slide back the outer cv boot,clean the grease from around the inside of the cv. At the top of the drive shaft where it is inserted into the cv is a circlip, you might not be able to see it, but trust me its there. With the shaft F/T in the vice get a big drift and a lump hammer and hit the end of the cv (the edge that slides over the shaft there should be a little raised edge.) hit it hard enough and it will overcome the circlip and slide off.(the circlip is more of a round spring clip)
        www.overfab.uk
          Cheers dude, I'll #### it tomorrow.
            make sure it level on the shaft it will not come off easy as said big hammer or cut it off
              Done!
              BFH + LOW = CVs off
              Tyres changed too, now ready for the rest of the bits to turn up so I can put it all back together again...caliper refurb kits front and rear, hub assembly and carriers OS and NS, tie rods, ball joints to go...
