box or pump?
  • box or pump?
    sorry had to film it in hd
    Simple checks!
    Silly question but is the belt tight enough and is the idler pulley okay and not seizing? Also, what happens when you turn on the aircon and the headlights. Simple things but you never know! Apologies if you have already tried these.
      Hi mate,
      Power steering pump belt is slipping.
      I can see you turning the steering wheel.
      Gman.
      Edit.
      The pumps top mounting bolt has more than likley broken too.
        thanks i will check out them first thing
        cheers
          it was lose realy lose its not shuck its self lose thats for sure it was hard to turn eather way so how this come lose after i just had new belts fitted i wonder?
          off now to try it out
            worked a treat cheers dudes
