Nope - Not Going to Upgrade it as of yet: have ordered alot for it
I've ordered the following lot:
Engine Thermostat
Engine Water Pump
2x Bottom Radiator Hose
Top Radiator Hose
Air-Con Belt
Timing Belt Kit
With Tensioners + Idlers
Pulley Spring
Engine Fan Belt
Power Steering Belt
Rocker Cover Gasket
Front Brake Discs
Front Brake Pads
Front Brake Fitting Kit
Rear Brake Drums
Rear Shoes
Rear Brake Fitting Kit
Manual
+ Fuel Pump Overhaul Kit
I know it sounds like a overkill for a Fuel Leak
But I might as well do all the gaskets and when you do that you might as well do the following:
Change Cam Belt - Better Safe Than Sorry
Change the Water Pump - I'm Local to it
Change the Radiator Hoses - Might as Well
Replace All Gaskets on Fuel Pump - Safer Than Sorry
Change The Other Belts - Safer Than Sorry
Change The Coolant / Anti-Freeze - God Knows When That Was Last Done
Blank Off The EGR Valve - In the Same Area
Replace Rocker Cover Gasket - Its Old & Brittle - Like Me I Suppose
Change All The Breaks - If I didn't Have Enough To Do Already
Well at least I'll busy Next Weekend doing this lot.....
Wish Us Luck
Engine Thermostat
Engine Water Pump
Top Radiator Hose
Air-Con Belt
Timing Belt Kit
Pulley Spring
Engine Fan Belt
Power Steering Belt
Rocker Cover Gasket
Front Brake Discs
Front Brake Pads
Rear Brake Drums
Rear Shoes
Manual
Wish Us Luck
