Originally posted by Paullen
View Post
another project reaching completion.
I would recommend a stainless steel system. Do you want a full system (right to the back exits at the rear) or a half system (exits around the rear passenger door just in front of the rear wheel). I have a half system in 3" from the manifold to a 3" bullet silencer exits under the truck just past the transfer case.You can have a system like this in 316 grade stainless steel and a 1.5mm wall thickness for around £300. For a full system around £500 these will be custom built to your requirements, noise level etc. Takes about a day to build and weld up a full system.www.overfab.uk
