Originally posted by KERRSURF
View Post
3rd gen HELP HELP HELP- heater
If it is scale, I've had some joy in the past using kettle descaler (having removed the matrix of course). Filled the matrix and left it an hour, jobs a good un.Originally posted by Bogus View PostWater might pass through freely but any scaling on the tubes can inhibit heat transfer. If you live in a hard water area , or your Surf has, and previous owners have been topping up with tap water, not bothering with a decent coolant mix, all this is quite possible
Matrix block
Caustic soda often is good as a last resort and usually the best cleaner you can use.Originally posted by andyverran View PostIf it is scale, I've had some joy in the past using kettle descaler (having removed the matrix of course). Filled the matrix and left it an hour, jobs a good un.
Yes as I said above a two part system, second flush is used neutralise the first. Didn't work for me as I already said.Originally posted by Jameswallace View PostMakes sense about the scale
I live in a hard water area, but i do use a high percentage of antifreeze
Is there a descaler you could run throygh the entire cooling system or would that be a recipe for disasterBrian
It's better to always use distilled water for the cooling system, especially if you are in a hard water area. Unless you use a premixed coolant, like the Toyotas or Halfords type coolants. In that case you don,t need to add extra water.Originally posted by Jameswallace View PostMakes sense about the scale
