no go
  • no go
    hi, had a leak on fuel pump so hubby took it of, had it reconditioned all put back but no go, fuel getting to pump but not injectors, what you reckon chaps, cheers
    Air in the pipes?
    Loosen all the nuts at the injectors and continually crank the engine until you see fuel spurting out.
      Air in the pipes?
      hi, did try that but no go, getting baffled, cheers
        Timing mark on the side of the pump aligned with the corresponding mark on the engine casing?
          will check that in morning ta
            timing mark on pump ok, still no go, whats he done to my motor,
              Maybe trade hubby in for a newer model.
              Sent from the iPad you "lost"
                helpful
                  Are you able to see fuel coming out from the pump on the supply to the injectors, just to rule out a blockage within the pump? Also, I assume the pump is mechanical and not needing a fuse to operate?
                  I don't know much about the LN 130, as ours is the KZN185, and the last vehicle I needed to strip out the fuel delivery on had a Merc 2.7 CRD setup.
                  If fuel is getting out from the pump, and still not getting to the injectors, do you have any other hose you could fit between the pump output and the injectors?
                    hi, fuel getting to the injection pump, opened pipes to injectors no fuel, pump been stripped and reconditioned, baffled,
                      Have you got a way to test the injector pump? Have you taken all the pipes off between the injector pump and each injector, that way you'll be able to see if fuel is leaving the injector pump, if not then I'd look at that, if so have you somehow got a blockage in each pipe?
                        The spill control valve (SPV) is probably stuck shut.
                          Just an idea... Before any major surgery, I replaced the fuel filter on mine and had no joy getting her to run, I pumped / primed it and turned it over repeatedly with no joy.
                          A friend appeared wit ha can of easy start and sprayed it straight down her throat /air intake and after a bit of turning over she jumped back to life....
                          __________________
                          Back in the day Baby
                            sorted
                            thanks for youre help chaps, got a cheap fuel pump fitted running smooth no leaks, had new water pump fitted well happy cheers
