The driver's side window switch is knackered. Do I just replace the entire switch unit? IE, is the board built into the switch panel? I ask because its the relay on the board that's gone.
Driver's side window - switch gone
OK, so it's not the relay on the board. Replaced the switch with one from a scrappie and the problem is still there. IE, the window winds down but the motor keeps going. Then if I hit 'up' the window only comes up with some help from me and the motor keeps grinding on when the window is closed. Anyone any idea what the problem is?
