hi, past my surf on to my daughter, had it since 2007, loved it, she loves it, it had a leak on the fuel pump for some time, stopped leaking when warm and in warm weather, son in law said I will put new top seals on pump brave lad, he did job stopped leak but, it ticks over, rev it no turbo, white an black smoke misfire well rough, what has he done chaps help
unlucky
Originally posted by BUSHWHACKER View PostWhite smoke is air in the fuel and black smoke is unburnt fuel. If both are happening then something has been disturbed or not put back together correctly, either way the top needs to come off the pump again to check I'm afraid.
Originally posted by caney View Posthi again, is it possable he moved the pump putting the timing out
See the third photo from the bottom here....
http://toyotasurf.asn.au/techsite/fuelpump.htm
