Cold Garage
    Insulation is the way forward I think too.
    When I extended my garage (prefab concrete panels) I insulated the walls
    and roof with 3" polystyrene sheets, plasterboard, taped joints and then
    painted, also double glazed windows.
    There is a space heater in there but I haven't needed it yet, -1 a couple
    of weeks ago too.
    Still on a mission.
      Originally posted by slobodan View Post
      Heat pump technology, if the conditions are right 1Kw electric in. 3Kw of heat out.
      Ahhh I thought he ment it was an electric heater
        Got one here...yours for £70. Pay your own postage mind....
        Fanks Gra I got all excited then saw the bit about postage
        Blagged one off eBay less than £15
        Garage will be insulated, using Airtec foil, apparently the same insulation value as 55mm of polystyrene......
        UPDATE
        With the portable air con unit it has raised the garage temperature from 8' to 13' in under 30 mins
        Will see how effective it is when it gets really cold....
        Eat.Sleep.Surf.Repeat.
